How do I start confluence in safe mode or with specific plugins disabled directly from the command line?
Sorin Sbarnea (Citrix)
November 5, 2012
I am looking for a solution that would allow me to start confluence in safe mode (all plugins disabled) or to specify which plugins to be ignored?
I am doing this because I try to do an updrade from 3.5.x production confluence to latest 4.2.x confluence and the upgrade seems to fail due to some plugins.
Also, it would be helpful to know how can I upgrade plugins before upgrading confluence, this seems like a chicken and the egg problem: plugin x is blocking upgrade but there is a newer version of the plugin which is supposed to work with the newer confluence.
LuizA
November 6, 2012
Hi Sorin,
Just in addition to Vicky's answer, as you're performing an upgrade you can disable all the plugins that you want to disable in the beginning of the upgrade(Confluence 3.5.x) and so upgrade and just enable again in the latest version (4.2.x), and in this meantime you can check at our https://marketplace.atlassian.com/ and search for the latest versions of your plugins that work with Confluence 4.2.x.
Best Regards,
LJ.
November 8, 2012
Preparing an upgrade: this means that I have a script that replicates confluence 3.x database which I am trying to upgrade on another machines using Confluence 4.x. As you can imagine I do not have another 3.x instance for test and I do want to have a slipstream upgrade process.
Usually when I found problems on the 4.x-test-instance I do fix them in production and do the upgrade again. Disabling the plugins in production is not an option.
vkharisma
November 6, 2012
Or this one for Confluence 3.5
vkharisma
November 6, 2012
Hi Sorin,
You may want to refer to the following doco:
Disabling or Enabling a plugin
Hope this helps, Vicky.
Learn more
