I have used the example in the article, and while I can successfully do html include macro to show http://www.google.com, if I put it in the iframe in html macro, it shows nothing.
If I put /dashboard.action info the iframe, it does work, just not any external. Whitelist is turned off at this time.
Hi Mark,
If you are on 5.8.15+ of Confluence, this is likely due to a security fix implemented to prevent clickjacking.See Confluence pages in iFrame no longer display after upgrading to 5.8.15 for a workaround. Note, that following the workaround will make your Confluence instance vulnerable to clickjacking so we don't recommend implementing. Follow at your own risk.
Jennifer Bennett | Confluence Support
Unfortunately, that link results in 403 forbidden. Is there a public version of the workaround available?
I still cannot access the workaround you mentioned due to Atlassian permissions.
Please let me know where I can find the workaround.
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!Online forums and learning are now in one easy-to-use experience.
