×This question is in reference to Atlassian Documentation: Deleting a Page
So we have an issue where it looks like someone created a page with invalid characters in the title and now when we try to goto the page we get a runtime error. So with that being said, I was hoping for a back end way to delete the page...
so I've hit another snag. So I did a query against the database (MS SQL Server) and got the records in the content table but my new issue is that there is no PageID. That being said, Is it safe to turf from the database directly? and If so, does anyone know what all tables I have to reference?
You may not have to go through all this trouble. If you can figure out the pageId, then you could simply press delete on another page, edit the pageId attribute to be the page you want to delete, and press enter to load the URL and it should update to delete the page you want.
e.g. https://<myConfluence>/wiki/pages/removepage.action?pageId=12345678
so if the pageId for the page you want to delete is 23456789, just replace pageId=12345678 with pageId=23456789
This might avoid having to use the API, CLI, or database.
I just took a look, and maybe that wouldn't work either, but it's worth a shot as a first option.
@Stephen Deutsch how can you find the ID of a page if you are not able to open it anymore - the only way I found in the past was SQL see my suggested solution. You made me afraid and I tested it - it works adding the pageid instead of 123.... like you suggested
Well, if your page has special characters in the title, then you can just search for it and copy the pageId out of the link URL. If it's not, one thing you could do is to open the browser console (I like to use Chrome for this) on the search page, switch to the network tab, run the search (so that it will show a request to the confluence server for the search), click on the request, and click the Preview tab. Then expand the "results" section, and you should be able to see the pageId next to the page titles.
I had similar problems in the past and fixed them without CLI
should work
best Robert
p.s.: Just found it:
select * from bodycontent join content on content.CONTENTID=bodycontent.CONTENTID and content.SPACEID='YYY' where body like '%XXXXX%';
As a result you find a list of pages - look for the line which fits your page and you find the ContentID we are looking for in third column named CONTENTID
If you can find the id of the page then you can use the API to delete the page. We ran into a similar issue and I had to first use the API to get a list of the pages in the space, then find the broken page in the list and get the page ID, then use the API to delete the page.
Since I'm not super familiar with confluence, how do I go about doing that...I'm not really a developer...I can code up some simple things but not super proficient at it...
You can try the Bob Swift CLI plugin since you may not know how to create a script to do it.
https://marketplace.atlassian.com/plugins/org.swift.confluence.cli/server/overview
