How do you duplicate a smart multi-row field using edit controls for confiforms?
Benjamin Rios February 9, 2023
I have created a form which has a date field, a smart multi row field, and a notes field.
I then display the data of this field using a table view which includes the fields listed above as well as an edit controls for confiforms which enables in-line editing and duplication of the schedule.
The issue I am facing is that when I select the "copy" button, it duplicates the schedule to the following day, but it appears that when I change any data within the duplicated smart-multi row, it also changes the stored data of the previous days schedule.
Is there anyway to duplicate a smart multi-row as you "unlink" the stored data?
Benjamin Rios May 3, 2023
Hi @Alex Medved _ConfiForms_ has the copy/unlink feature for smart multi rows been implemented?
Yes, since version 3.2.1
Works perfectly!
Now...I have an additional question regarding Smart Multi-Rows.
I am attempting to pass a smart-multi row between one form to another using an IFTTT macro.
To lay it out in more detail I have 1 form called [questions] which holds the fields to be used in the smart multi row which are:
1. Question
2. Correct Answer
3. Test Taker Answer
4. Score
Then I have another form called [createTest] which has three fields:
1. testName
2. testQuestions (smart multi-row using fields from [questions] form
3. assignTest
Also has an IFTTT which tracks the [assignTest] field and when the field changes it passes all of the fields above to the [testTaker] form as a new record.
Lastly I have a form called [testTaker] which has the following fields:
1. receivedTestName
2. receivedTestQuestions
3. testID (hidden)
The problem is that when I make an edit to the [receivedTestQuestions] values (within the smart multi-row) all values related to this field get changed as well.
Is there any way to unlink this so each time I pass the multi row I am not passing a reference?
Sounds highly complicated to me... but consider using this to copy data - https://wiki.vertuna.com/display/CONFIFORMS/Configuring+ConfiForms+IFTTT+actions+and+rules#ConfiguringConfiFormsIFTTTactionsandrules-CopyConfiFormsData
Smart fields in ConfiForms are links between forms and records.
PS, Honestly, not sure why the smart multi-row should be used here... but it's probably not my business
Alex
Benjamin Rios May 4, 2023
Thank you for the response @Alex Medved _ConfiForms_ !
I think...I may have overcomplicated stuff...my bad habit haha.
But as always thank you for your help 👍
February 10, 2023 edited
Hi @Benjamin Rios
There is no way you can do it now, but we understand that copying a record with a smart multi-row should behave different to what copying of any other "smart field" or actually any other field type does
We will make a change so the "copy" function will work the way you need it from the beginning
Please watch the marketplace listing for ConfiForms to get your self notified when it's done
Alex
Benjamin Rios February 10, 2023
Understood!
