How get embedded draw.io diagrams when accessing a page via Confluence REST API?
Markus Perndorfer January 8, 2020 edited
A draw.io diagram on a page used to be an embedded, base64-encoded png in the body.export_view of a page, e.g:
GET https://confluence.company.com/rest/api/content/123456789?expand=metadata.labels,children.page,version,body.export_view
Old Response
"id": "123456789",
"type": "page",
"status": "current",
"body": {
"export_view": {
"value": "<img class=\"drawio-diagram-image\" src=\"data&colon;image/png;base64,c0debabe..."
But since a recent upgrade of the draw.io plugin (8.5.1 -> 9.2.6), I get a useless JS code block for every diagram on a page
New Response
"id": "123456789",
"type": "page",
"body": {
"export_view": {
"value": "<span id=\"drawio-macro-content-cae9a5a5-bb84-4eba-83d2-b2f5798cf226\" style=\"position:relative;display:inline-block;max-width:100%;overflow:hidden;border:1px solid transparent;\"></span>\n\n<script type=\"text/javascript\">\n(function()\n{\n\t$ = AJS.$;\n\t\n\tvar graphContainer = document.getElementById('drawio-macro-content-cae9a5a5-bb84-4eba-83d2-b2f5798cf226');\n\tvar DrawioProperties = { contextPath : AJS.contextPath() };\n\t\n\tvar readerOpts = {};\n\t\t\treaderOpts.loadUrl = '' + '/rest/drawio/1.0/diagram/crud/..."
Is there any way to replace the JS code block with e.g. link to the rendered diagram?
(Maybe a configuration option for the plugin?)
Theoretically I could parse the JS script block and use the properties of readerOpts to construct the link to the rendered diagram that's available as attachment on the page anyway, but I really don't want to go down that rabbit hole.
David Benson _draw_io_
January 8, 2020
Are you sure it's a change to the plugin and not a Confluence update that caused the change?
Reasonably sure, yes. (I'm only a user of this particular confluence server, not an admin)
The change of the output format directly coincides with the plugin update.
I was able to dig up the previous version: 8.5.1
Markus Perndorfer January 14, 2020
Any chance to get the old behaviour back?
Boris
January 30, 2020
We have implemented an admin setting which will act as a switch. Default will be 1 which will embed the diagram in the output.
It will be in the next release.
Markus Perndorfer January 30, 2020 edited
that's great to hear!
Looking forward to the next version, so I can remove the JS script block parsing again...
Any ETA on the release?
Markus Perndorfer February 24, 2020
Is this fix in 9.2.8?
Boris
February 24, 2020
It is. Search for 'emailpreview' in the docs here.
ee
November 16, 2021
it's version 9.1.
after setting emailpreview=1, the export_view is still js code.
David Benson [draw.io]
November 16, 2021
9.1 is too old, you need to update to get the change.
