How to Generate Dummy Data
Jack Nolddor _Sweet Bananas_
Hi all,
As part of my development process, I need to simulate a Large Instance to ensure the quality of my products.
Is there any way to generate dummy data in Confluence or Bitbucket?
I'm looking something similar to Jira Data Generator
Regards
Shannon S
January 11, 2018
Hi Jack,
There's test data for developers here:
I can't tell if you can generate an instance of a specific size, but perhaps that can help you?
Shannon
Better than nothing but what about bitbucket?
Shannon S
January 15, 2018
Hi Jack,
For Bitbucket I don't see that there is anything similar. We do have the Performance Testing Framework that you could use, otherwise, I would recommend downloading a public repo from somewhere and uploading that for testing.
Shannon
