How to Hide a custom field on edit screen Jira
Muhammed Sharifi October 17, 2018
Hello
I want a custom field that should be hide when we want to edit the issue,
I tried adding some script at the discription of the field at field configuration but it didnt work,
apprecited every one's cooperations
Alexey Matveev
October 17, 2018
Just remove this custom field from the edit screen for this issue type (project settings -> screens)
Hi Alexey Matveev
Thanks for reply dude, I went through that way to remove it from Edit screen but the problem is when you remove it from there the field is being removed from view screen too. and when I added it back to view screen it was there on the edit screen.
 any other suggestion ??
Alexey Matveev
October 17, 2018
It means that you use the same screen for the view and edit screens. You should create a separate screen for the edit screen.
Have a look at this link:
https://documentation.catworkx.com/jppm/latest/configuration/configure-the-project-portfolio-project/create-screen-scheme
Muhammed Sharifi October 19, 2018
thank you, separating screens worked fine for me.
Alexey Matveev
October 20, 2018
@Muhammed Sharifi You are welcome! If you feel like my answer helped you, kindly accept my answer.
