×How do I create a custom code block macro? I would like to have macros for languages we use with a standardized look.
This is what I have created in Configuration -> User Macros:
## @param codetitle:title=Code title|type=string|required=true|desc=Title of the code macro ## ## Macro title: Python Single Code Line ## Macro has a body: Y ## Body processing: unrendered ## Output: Selected output option ## ## Developed by: me ## Date created: 07/10/2016 ## Installed by: me <ac:structured-macro ac:name="code"> <ac:parameter ac:name="title">$codetitle</ac:parameter> <ac:parameter ac:name="theme">Default</ac:parameter> <ac:parameter ac:name="language">py</ac:parameter> <ac:plain-text-body><![CDATA[insert your code here]]></ac:plain-text-body> </ac:structured-macro>
Unfortunately, this does not work: the title is not replaced by the value of $codetitle, thus just the string "$codetitle" appears in the title bar no matter what value the string $codetitle has.
Additionally, any modifications to the body are ignored. You can insert what you want into the body, the macro always displays "insert your code here".
How do I have to alter this macro in order to get it working properly?
To the first question:
I guess you need to write $paramcodetitle. That is the proper way to use the macro parameters.
If this doesn't work name the parameter Codetitle (with a capital):
@param
Codetitle:title=Code title
and then use the parameter like this: $paramCodetitle
