How to add comment in page history
Cecilia Laustriat
February 15, 2018
Hi all,
I know the usual Page History macro but it lists all the modifications of the page and it is impossible to filter.
Previously I used a macro slightly different which allows filtering using the presence of a comment.
Unfortunately, I do not find this macro anymore.
Do you have any idea?
Best regards,
Richard
Hermance NDounga
February 27, 2018
Hi Cecilia,
I don't think I remember having seen this macro on Confluence. Do you remember which deployment you had when you used the macro you're mentioning? Or you can check the three first apps here.
Register today
