How to add custom Javascript in Confluence pages?
Roland Benedetti July 11, 2011
I figured out how to add javascript calles in the header or footer but can't figure out how to add some Javascript in the pages itself.
Anybody knows?
3 votes
Matt Ryall
July 11, 2011
You could write a User Macro to do it. You need to pick a name, set the output format as "HTML" and put your JavaScript content in the body. Then you just put this macro into your pages.
If you need different JavaScript on every page, Confluence ships with a disabled HTML macro that you can enable in the "Plugins" list under the Administration. Then you can write an {html} macro with the <script> tags inside it.
Roland Benedetti July 16, 2011
Hi Thanks Matt,
But this means the Macro should be added to all the pages manually, I was more looking to add something on all pages, once for all.
Any idea?
Matt Ryall
July 17, 2011
In that case, I'm not sure what your question means. If you have added JavaScript in the header or footer via Administration > Custom HTML, you should find it already on every page.
David at David Simpson Apps
This question is very similar or at least related to:
https://answers.atlassian.com/questions/3054/javascript-inclusion
Colin Goudie
July 16, 2011
Roland, take a look at the web-resources Module type. If you add a plugin with one of these in there then you can have your own JS files added to all pages. Have a specific look at the contexts, such as atl.general for example
http://confluence.atlassian.com/display/CONFDEV/Web+Resource+Module#WebResourceModule-WebResourceContexts
Anders
April 2, 2018
插入宏 -html
<SCRIPT type="text/javascript">
var element = document.getElementById('main-content'); element.style.backgroundColor = "#33CCCC"; </SCRIPT>
Yagnesh Bhat
August 3, 2014
<web-resource key="somekey" name="some description">
   <resource type="download" name="yourfile.js"    location="/js/your file.js"/>
   <context>page</context>
</web-resource>
In your atlassian-plugin.xml , include your javascript as a web resource for page context as above.
Bob Kennedy
I tried adding custom code in Custome HTML but the code does not appear in the pages themselves.
Sean King
September 5, 2013
If you want Javascript on an individual page use the {html} macro. Otherwise for all pages add your script in appropriate place in the the CustomHTML screen of the Admin Console.
Nikhil Naoghare
Hi Roland,
You can try this example http://come2niks.com/?p=542 this really works.
Nikhil
Matthew J. Horn
April 11, 2013
Nikhil, this link no longer works.
Jay Ji April 25, 2013
i tried this but didn't work.
jhammons
July 11, 2011
Hi Roland,
Please refer to the following document:
Be well,
Jason Hammons
Atlassian - San Francisco
Jennifer German January 9, 2017
That is for JIRA.  This question is about Confluence.  Therefore that link is not useful here.
