I am using macro on Confluence related charts, but cannot find a option to add values. Can you please let me know is it possible? Thanks!
Jovanka
What is the source for your chart?
If this is a Confluence table, you may click the "Manage connected data" option and select a chart as target:
The chart macro will be inserted just underneath your table.
From the chart options, you can choose from 3 types of graph: bar, line and pie. You can also configure your X axis and data series and customize the look and feel for your graph, providing a title and axis labels.
I hope this helps!
Hi @Jovanka Jovicic ,
To provide more specific guidance, it would be helpful to know which chart macro you are using in Confluence.
I do not have this option and version is data center not cloud, so maybe it can be the reason...
This learning path offers short, self-paced courses to help software teams systematically manage components and services. Compass provides a unified interface for tracking distributed software architecture and team collaboration.
Learn more!
