On a confluence page with multiple tabs, how to add tables side by side inside one of the tabs page macro. Each table has multiple rows and columns. (intend to add 2 tables side by side)
Hi @Rizwana_Firdaus ,
Tabs are not a default Confluence feature, so your Confluence site must be using some Marketplace App. If you can find out which App is in use, this will help the community to help you. Also, do you use Confluence Cloud or a self-hosted Server / Data Center version?
