I am using the Jira for confluence macro to display a list of tickets and their associated value in a column we are calling Revenue. I want to use the table transformer to add a dollar sign ($) in front of the values - as Jira does not have this field formatted as currency.
Right now I see:
Key | Revenue
Ticket 1 | 124.5
Ticket 2 | 1000.0
I have tried utilizing Concat or Format for SQL and can't figure out how to append the '$' in front of all
SELECT CONCAT('$', FORMAT('Revenue'));
Hi @Megan,
You may use the following SQL query:
SELECT 'Key',
FORMATWIKI("$" + 'Revenue') AS 'Revenue, $'
FROM T*
Hope it helps your case.
