How to bulk delete blog posts?
Susanne B August 22, 2019
Hello!
I want to delete blog posts from a space. In my particular case, I can delete all, but it seems better to delete only posts that are older than a selected date.
I'm looking forward to tips.
Greetings Susanne
Teodora V _Fun Inc_
Hi @Susanne B
What comes into my mind first is creating a page (e.g., Posts for Deletion) and reordering all posts which you want to delete as its child pages. Then remove the page and in the pop-up window check the "Also delete child pages" mark.
This may work if you have dates in your blog post titles to sort them out while reordering :)
Andy - PTC Redundant
August 22, 2019
Ironically I love this answer because my personal blog posts are per month & year which makes deleting old data quick and easy !
Teodora V _Fun Inc_
Yes, exactly! :) Order is King!
Like • Andy - PTC Redundant likes this
Thanks for the quick reply.
Moving the posts would also only go individually and not collected at once, wouldn't it? So that I have to open and move or delete all posts one after the other.
Thanks anyway.
Teodora V _Fun Inc_
Use the Space tools - Reorder pages menu. It will lead you to the page tree, where you can drag n drop the posts. Attached you can see my personal space, for example in Reorder Pages mode. If I want to delete my Articles folder, it will bulk delete the blog posts also.
I especially want to delete blog posts, they are not displayed in the page tree and can therefore not be moved by drag&drop.
Is there an option which can be activte for display blog posts in the page tree?
Teodora V _Fun Inc_
Oh my, I understand your case, I made a few sample pages in my Blog section and try to reorder them. What I suggested was possible if the content is in your main Confluence space.
There is a feature request from 2004 for bulk-type operations with status "Probably Never". :(
Found some articles in the documentation space:
https://confluence.atlassian.com/confkb/how-to-bulk-delete-blogposts-of-a-confluence-space-manually-from-confluence-database-using-sql-commands-849065514.html
https://confluence.atlassian.com/doc/blog-posts-834222533.html
Apparently, the manual option is still deleting the posts one by one. Hope someone will have a better solution than me.
Like • Josh Carpenter likes this
It's just that Confluence is designed to capture information and not to delete it. So that I will proceed manually first. Now I don't want to work directly on the DB, maybe when I'm better at the topic.
Thanks anyway!
Vincent de Regnauld de Bellescize
November 4, 2022
Hello there,
We were able to successfully delete all blogposts from a space with a groovy script and a CQL query (requires Scriptrunner, use console).
Hope this help.
import com.atlassian.confluence.pages.PageManager
import com.atlassian.sal.api.component.ComponentLocator
import com.atlassian.confluence.core.DefaultDeleteContext
import com.onresolve.scriptrunner.canned.confluence.utils.CQLSearchUtils
import com.onresolve.scriptrunner.runner.ScriptRunnerImpl
def pageManager = ComponentLocator.getComponent(PageManager)
def cqlSearchUtils = ScriptRunnerImpl.scriptRunner.getBean(CQLSearchUtils)
def cqlQuery = "space = 'YourSpaceKey' and type = blogpost"
def cqlSearch = new CQLSearch()
def pages = cqlSearchUtils.searchForPages(CQLSearch.fromQuery(cqlQuery))
pages.each{ pageToDelete ->
        pageManager.trashPage(pageToDelete, DefaultDeleteContext.DEFAULT)
        log.error pageToDelete
August 22, 2019 edited
@Susanne B : Sadly there is no standard "search => criteria:<date // delete" function.
But... it's Server, so how hardcore do you want to get??  A macro could be written if your Atlassian Admin / Development team are up for the challenge:
https://developer.atlassian.com/server/confluence/
I hoped that Scriptrunner would provide me with a suitable built-in script like the one that deletes obsolete comments on pages. Unfortunately no.
We may find someone in the development who feels called to do so, but the requirement probably doesn't come often enough.
Thank you very much!
