How to call the Copy pagetree built-in scripts (Confluence Script runner)
Koen Gillard (CalmWare) August 1, 2016
Dear
I'd like to call the built-in Copy Pagetree script from within an existing Custom REST Endpoint.
Is this or any other interaction with the built-in scripts documented somewhere?
Like, what's the location of the script, what are the (required) arguments etc
Thanks in advance
Kind regards
Koen Gillard
Volodymyr Havryliuk May 12, 2020
In order to tests where found when running them from Idea, package with your tests should be specified in Scriptrunner UI
Volodymyr Havryliuk January 16, 2019
Hello, Koen Gillard. Did you find answers for your questions?
Jonny Carter
November 10, 2016
The class is com.onresolve.scriptrunner.canned.confluence.admin.CopyTree. You can find it in the plugin jar (after unzipping it) under com/onresolve/scriptrunner/canned/confluence/admin/CopyTree.groovy.
There are some notes in the JIRA documentation about calling built-in scripts remotely via REST calls and hacking together your own "canned" script. The same concepts should roughly translate to Confluence.
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
