×I'm trying to change the system default timezone for Confluence but I can't really find it in the admin menu. How do I do it
there is no option for that in the admin console of Confluence. Confluence is using the servers' timezone as default.
There is an long open issue for that:
https://jira.atlassian.com/browse/CONFSERVER-16057
Maybe you want to vote for it.
Thanks. It's surprising that this can't be done via the admin console. So I only need to change my server's timezone right?
Update: I tried changing the local time on my server. However the system timezone inside Confluence is not changed after I restart Confluence.
Running "date" command in my console does return the correct timezone
There is another answer here:
Maybe setting the JVM parameter works for you.
