Im not sure how to create the no print macro and use it in page. I found some Confluence documents to go to settings and create user macros, but im not finding those options in my confluence interface.
Need help in creating the macro.
Documentation regarding User Macros can be found here (including an example for "noprint"), Writing User Macros | Confluence Data Center and Server 7.19 | Atlassian Documentation
User Macro creation is limited to Confluence Administrators, if you are not an admin you won't have the ability to create them.
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻♂️Online forums and learning are now in one easy-to-use experience.
