I want to add a snapshot of jira issues using "jira issues macro".
However, refesh mode is always updating results which doesn't fulfill our requirements.
Any idea how to disable refresh mode for jira issues macro?
Hi @[deleted],
I think the macro is to give you current data from Jira.
If you need snapshots, the best way is to take a snapshot yourself - print the page to file.
Hope this helps.
Hi community,
Any other alternatives?
The goal is to get data snapshot from jira without printing the page.
Many thanks
There is no export function in Jira Dashboard
Taking a picture will not help as there will be no hyper links. It will be good to have a functionality for stop refreshing the query.
Example use:
I use JQL with latestUnreleasedVersion() function in dashboard so I dont need to update it every time. Where as, for the sake of confluence charts I need to create filter for every release which is unnecessary. If confluence have a capability to stop refreshing the page, it will be easy to refer back the old release page in confluence with the snapshot of shart at the time of release and not with the updated one.
