Hello all,
I um currently developing a plugin for Confluence which will enable/disable Blueprints for a specific space through the Confluence Java API.
I reviewed the online technical Java doc but was unable to find how to achieve my goal.
Has anyone run into this challenge before?
Thanks a lot
What developpers would need for this case is access to the BlueprintStateController (com.atlassian.confluence.plugins.createcontent.BlueprintStateController) if possible. This class does exactly the job but is not available for injection
Did you eventually managed to bypass this limitation ?
Yes I did, but it's rather a dirty hack. I copy/pasted some code in the BlueprintStateController and some other classes down the line. Basically it's "just" a matter of pushing values in bandana
{code}
private void enableBlueprint(UUID blueprintId, Space space, String bandanaKey) {
if(blueprintId == null) {
throw new IllegalArgumentException("Blueprint UUID is required.");
} else {
Object bandanaContext = space == null?new ConfluenceBandanaContext():new SpaceBandanaContext(space);
Set disabledBlueprintsIds = (Set)this.bandanaManager.getValue((BandanaContext)bandanaContext, bandanaKey);
if(disabledBlueprintsIds != null) {
disabledBlueprintsIds.remove(blueprintId.toString());
this.bandanaManager.setValue((BandanaContext)bandanaContext, bandanaKey, disabledBlueprintsIds);
private void disableBlueprint(UUID blueprintId, Space space, String bandanaKey) {
throw new IllegalArgumentException("blueprint UUID is required.");
} else if(!blueprintId.equals(BlueprintConstants.BLANK_PAGE_BLUEPRINT.getId())
&& !blueprintId.equals(BlueprintConstants.BLOG_POST_BLUEPRINT.getId()))
Object disabledBlueprintsIds = (Set)this.bandanaManager.getValue((BandanaContext)bandanaContext, bandanaKey);
if(disabledBlueprintsIds == null) {
disabledBlueprintsIds = Sets.newHashSet();
((Set)disabledBlueprintsIds).add(blueprintId.toString());
} else {
throw new IllegalArgumentException("You cannot disable this blueprint.");
{code}
Would be simpler and more stable in the long run if the BlueprintStateController was a public spring component
Hello Sebastien
Many thanks for all those details.
Still how did you managed to find the Bandana Keys to get the list of disabled Blueprints. Couldn't find the right BandanaKeys to do so?
The bandana key in question is : "com.atlassian.confluence.blueprints.disabled"
Super! Many thanks for your help.
Hi - i've played around with setting values on the bandana global context but I seem to only ever getting null
Would anybody be able to share more of how they have managed this? It's really frustrating !
Thanks in advance for your time.
Could you show an example of your code ? The examples shown above have been working pretty fine so far.
Hi Nicolas,
We have a feature request to create the Javadocs for Blueprint API here, as we don't yet have that:
I am not aware of a way to do specifically what you request, but you could add your Blueprint as a promoted Blueprint using the following procedure:
I hope this helps.
Shannon
Hello @Shannon S,
Thank you for your reply. I watch this issue now.
There is actually a way to enable/disable Blueprints for a space with the help of the Confluence REST API:
curl -u admin:admin -X PUT http://server:port/rest/create-dialog/1.0/modules/883d16f5-6eaa-46db-9201-54a1eb9cfcac?spaceKey=VS
curl -u admin:admin -X DELETE http://server:port/rest/create-dialog/1.0/modules/883d16f5-6eaa-46db-9201-54a1eb9cfcac?spaceKey=VS
In the example above, admin is the user (with password "admin"),
http://server:port/ is the instance base URL, VS is the Space key and 883d16f5-6eaa-46db-9201-54a1eb9cfcac is the Template ID - which can be found on the "UUID" column of the "AO_54C900_CONTENT_BLUEPRINT_AO" table in Confluence database.
(I got this hint from the Atlassian support team by the way)
However, I would rather use the Java classes instead of a REST call as it is required to authenticate first.
Hi Nicolas,
I was aware of the way via REST API, but not specifically of Java API, as it's not documented anywhere.
Hopefully someone will see this that knows if there is a way to do so, but what I'm hearing from the Confluence Server team is that it may not be possible.
If you do determine the way to do it, since it's undocumented, please let us know here in case any other users have the same issue.
Shannon
Read more 📚Online forums and learning are now in one easy-to-use experience.
