How to establish cascading check boxes/multi select in confluence form?
sumer bhalla September 13, 2024 edited
I have two smart multi selects. These are backed by a table view.
One for GENRE (Fruits, Vegetables, Dairy).
Other one for corresponding values (Apple, Banana, Carrot, Peas, Milk, Eggs).
Based on my selection on first multi select, values in second multi select should show.
Condition: My user has to select multiple genres.
Filtering is working fine, if user selects just one option in genre.
I need filter to work when two options are selected. For example: if Fruits and Vegetables both are selected in first multi select, second one should show (Apple, Banana, Carrot, Peas).
Goal: idea is to restrict user to select from available options only. I don't want my user to be selecting eggs, if user is looking for fruits or vegetables.
Note: I am a naive user here. Looking for a easier approach.PXL_20240913_114902625~2.jpg PXL_20240913_114848762~2.jpg PXL_20240913_115044827~2.jpg
Alex Medved _ConfiForms_
Hi @sumer bhalla
Added some labels to the question, so it would be easier to understand that it's ConfiForms related
From the original question it is rather difficult
Anyway, have a look at this video I have recorded for you
Hope it helps
Alex
Thanks @Alex Medved _ConfiForms_  it worked perfectly fine. Do you have any page listing such syntax?
Another issue: I want to use the info value attached to this record. Where info is the third column in the table. Below syntax is not working. OptionInfo is the text field to show the info value.
OptionInfo:[entry.OptionSM.Info]
What the "OptionInfo:[entry.OptionSM.Info]" should do? What are you trying to filter and where?
sumer bhalla September 14, 2024
I am trying to get the value from third column of the table. I have to show it in a text field on the form as well as our it on the JIRA issue.
Basically selection of Genre and Option will filter out the info.
What it should show when you have multiple Options selected?
It should concatenate the values in Info column, and put it on the text field as well as in the JIRA.
sumer bhalla September 16, 2024 edited
I need to print "Eggs Info; Milk Info" in Option Info field.
  1. How will it filter out the value from Info based on Option selected? Because i have tried Set value ruke and used this under Values to set OptionInfo=[entry.OptionSM.Info], but it is not working.
  2. Where should i put OptionSM.transform(info).asList?
  3. How can I fetch the Info values to put in JIRA issue while creating it?
Basically i want to do following:
Set OptonInfo = (Value from Info column) where Genre is selected Genre and Options are selected Options.
Honestly, makes no sense to me, but you can use the iterateAnPrint function, for example
OptionsSM.iterateAndPrint([entry.Options] [entry.Info] )
 I do show exactly on my screenshots where to put  these things...
Anyway, if you still want to have something like a Set Value rule... (and copy values over, insted of referencing them realtime) then
the expression for the parameters would be
OptionInfo=[entry.OptionsSM.iterateAndPrint([entry.Options] [entry.Info] )]
Let me rephrase the ask.
I want to get the value from Info column and set to a text field OptionsInfo, based on the selections made on Genre(GenreSM) and Options(OptionsSM).PXL_20240913_115044827~2.jpg
I get that - I have no idea why would yo do that... but OK, you can see my previous comment that answers your "ask"
I guess i got the solution.
Issue: I was not able to get the value from Info column using OptionInfo=[entry.OptionSM.info]
Reason: Reference to records checkbox was not checked for OptionSM
Lesson: Reference to records checkbox need to be checked, if user wants to filter out the Info from third column, based on selections made on first two columns.
Observation: If Reference to records checkbox is checked, and Option column has same value for two different Genre, then form will display that same value twice. And user has to select both to get the Info.
sumer bhalla September 17, 2024
Thanks a lot @Alex Medved _ConfiForms_
@Alex Medved _ConfiForms_ Can you help here? Thanks in advance.
Radek Dostál
September 13, 2024
Well, clearly this isn't native, it's custom, thus it's more for https://community.developer.atlassian.com
Whoever has made those html forms knows how the select lists (which seems like select2, most likely atlassian aui select2 fork) are set up, and there will be something in javascript that makes the current filtering work.
That depends on how those select2 fields are set up to do searches - whether it's server-side, where you would need to make the filtering inclusive for multiple options, or whether it's client-side, in which case, the javascript code needs to be made inclusive for multiple options.
Can't suggest anything concrete without seeing either the javascript or the backend filtering api method.
@Radek Dostál Can you explain in simple words? Are you saying that behavior of these multiselect is done at organizational/admin level?
I am using ConfiForms Field Definition and ConfiForms rules for Field Definition.
And here multiselect behaving with AND condition between Dairy and Veggies. I want it to behave with OR condition between Dairy and Veggies.
John Funk
Hi Sumer - Welcome to the Atlassian Community!
Can you share a screenshot of what you have?
@John Funk screenshots added
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
