How to filter for JIRA issues and receive it as text?
Gero Kassen
January 23, 2020 edited
I want to create a Confluence Page that displays a Release Report. I know that there is the Confluence built-in "Change log"-Template, but this does not do the job for me, because there are not enough details shown for each issue.
I could use the "JIRA Filter Results"-Macro and this gives me the issues I need (with all necessary information), but you need access to the respective JIRA project so be able to see the results of this filter.
I need to have the result in a way, so that people, who only have access to Confluence are able to see the Release Report with the predefined information. Is this possible in one way or the other?
Haran Kumar
January 23, 2020
Hi @Gero Kassen ,
I would be happy to help you given that , Can you explain a bit more on what are the predefined information that you are looking for ?
Regards
Haran
Gero Kassen
Hey @Haran Kumar
with predefined information, I just meant that I want to predefine the columns that are visible in the table that states the JIRA issues. So: nothing more than a regular JIRA Issue Filter.
When your question aimed at the location the information is located on: They are in JIRA.
A quick summary: I want to have a generated table with JIRA issues that has columns with the attributes, that I want to have shown, but in a format, so that also users without the permission to the JIRA project are able to view them.
