Hi All,
Good afternoon,
Here my query is in my confluence production version is 5.10.9 under General Configurations User directories when automatically synchronization is performed by system in LDAP as per LDAP settings .But After some time some particular users means like 92 users are not found or some users details with some other names updated like Kavala babu as Frank zara (or) some users trying to login showing as no user found error like that
So for this problem we temporary fix this as solution we are doing manual synchronization whenever daily this issue happens i seen in audit log whenever it happen like below
Example in auditlog: 3 Aug, 2018 04:30:37 System Users and groups User details updated User: xxxxxx Show more 3 Aug, 2018 04:30:37 System Users and groups User renamed User: xxxxxxx Show more Thanks
please provide the solution for this issue to fix permanently
santhosh
Hi Santhosh,
Without getting fully in to your application logs, here are some general suggestions to try:
Daniel
Hi Daniel,
Thank you so much for quicker response
In application logs not showing anything because sync not failed full synchronization completed in some secs only audit log shows as whenever this happens daily as user details updated or renamed to some other user
then i do the manual synchronization the problem is fixed for temporary
please suggest any other relevant fix or solution for this type of issue is occured
santhosh
