Added an anchor, shows up as grey box, but
1. it doesn't have a label, so is completely invisible
2. doesn't work
I've named the anchor "foo" and published the page afterwards. Navigating to the page using https://<url to page>#foo doesn't do anything.
Hi @tobias.fielitz - Anchors can be tricky sometimes (believe me - I made my experiences...)
did you check out 'view source' - this will show your site with content and all macros/addons on the page. There you will see if your anchor named 'foo' will appear.
Should look something like that:
Next thing is - from where did you try to link to the anchor? If you're linking from another space your link must look something link
spacekey:page name#anchor nameNow when I look on your example that might be the problem - do you want to send an direct link to someone? I have no idea how to generate them - my trick is - I create a link on page links-advanced to the anchor (like it's shown above) use this link and use the generated adress from browser.
The link contains something like the
/url/display/space/title(which might be tricky if special characters or spaces are used)/#titlewrittentogether-anchorname
Hi Fabienne, Thanks for the reply.
I would indeed like to link from an external source (from a comment in the code to be exact).
The process you describe seems far too complex to achieve such a common (and simple!) thing :(
Hi Tobias - than do the easy way - create the external link on a page for yourself (I have a page I just for myself in my personal space) where you create the advanced link
spacekey: page name#anchor name
-> click this link -> this opens the anchor link -> copy the adress from browser and use this
Shouldn't take you more than 1 minute I guess
I just wanted to show you how tricky it would be to create the link by your own by showing you all the parts ;)
Hope this works out for you!
