I have seen many documents, but I have found only the code that creates issues or projects, and I have not seen the code that get issues. Is there a api to get issues from jira to the confluence? I'd appreciate it if you could let me know the document for reference.
Dear @hyojoon choi ,
what would you exactly like to do? Convert a jira issue to a confluence page? After which action / upon which criteria?
So long
Thomas
I wanted to get the contents of Jira's field through the application link, but I didn't have any information, so I brought it through Rest Api. Thank you for your answer.
both applications have rest interfaces. You can read Jira issues (and their fields) and put this information in a Confluence page by creating/updating pages.
GET: https://jira/rest/api/2/issue/ABC-1234
Then you have to parse the returned JSON for your fields and convert it to a Confluence JSON.
POST: https://confluence/rest/api/content
So long
Thomas
was my answer useful? Then I would be happy when you click on the "green accept answer" button.
So long
Thomas
Read more 📚Online forums and learning are now in one easy-to-use experience.
