How to get a sum total of individual rows using page properties report
Dailin Young July 27, 2020
I have 4 different fields which i am using a page properties report to display with each row being an individual project entry. I would like to be able to sum the total of each column in an individual row to get an all in total. I am currently using Table Filer, but that only gives the option to add the columns, which does help since each row is an individual project.
Katerina Rudkovskaya _Stiltsoft_
Hello @Dailin Young ,
With the help of Table Filter you can both count total for columns and add Total column with the needed operation type. Is it what you need?
Best regards,
Katerina
Hi @Dailin Young .
Could you send us screenshots for better understanding?
Best regards,
Katerina
Dailin Young July 30, 2020
Hi @Katerina Rudkovskaya _Stiltsoft_ sure please see attached.  WHat i am looking for is to be able to sum up the totals by project and get a 'Totals" after 'OTHER Quote Amount' Column.PagePropertiesReporting_Sum_Total_By_Rows.PNG
