I need to get installed plugins list in java preferably. I looked at several confluence packages but could not find any. Your help is appreciated.
Hi @Abdurashid Vakhobov ,
You can use PluginAccessor to get the installed plugin list. Please find the java doc as https://docs.atlassian.com/atlassian-plugins-core/2.8.0/atlassian-plugins-core/apidocs/com/atlassian/plugin/PluginAccessor.html
Also, you need to include the respective dependency in your pom.xml and component-import for this package in the atlassian-plugin.xml.
Or you can use rest api to get the installed plugin details
https://ecosystem.atlassian.net/wiki/spaces/UPM/pages/6094960/UPM+REST+API
For more information on the rest api, please check this link https://community.atlassian.com/t5/Confluence-questions/List-of-user-installed-plugins/qaq-p/76276
Hope this helps!
Santwana
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
