How to hide PDF Export function for group of users using Custom HTML
Elena Oleksenko
Hello!
I found a method to hide Export to Word function using Custom HTML https://community.atlassian.com/t5/Confluence-questions/Disable-Certain-Tool-Options-for-Anonymous-Users/qaq-p/194521
But when I try to use this method for PDF export it does not work.
Is there an error in code block below or this is simply impossible - to hide this function in such a way?
#if ($userAccessor.hasMembership('test-restriction', $helper.action.remoteUser.name))
<style type="text/css">
##action-pdf-page-export {
display:none !important;
</style>
#end
Victor Florin Pana
Hello Elena,
In the title you said want to hide the PDF export and in the body you talked about Export to Word so I will assume that you would like to stop people from exporting the space no matter what option.
On a space level, you can always remove the users Export permissions, assuming that you have space admin rights.
Alternatively you can disable exporting on the entire Confluence instance: https://confluence.atlassian.com/confkb/how-to-restrict-the-ability-to-export-a-space-in-confluence-800699946.html
Victor
Elena Oleksenko
Hello Victor!
Thank you for the reply!
My explanation a bit messy, probably. I meant, I need to hide menu item "Export to PDF" from Tools menu only for one group of users. Users who are not in this particular group should be able to use "Export to PDF" function.
Victor Florin Pana
Hello Elena,
If you want specifically to hide it, unfortunately I cannot help you. But if you want just for it to be unusable for members of a group, although it might still be visible, then you can restrict this from the space permissions section. Simply ensure that the specific group, does not have the "Export" permission ticked.
Best regards,
Victor
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
