How to insert a link to an external weather widget?
Martin Kaufmann October 18, 2018
Hi all,
because users love eye candy, I want to insert a weather widget to my confluence page(s).
I am trying to use code like this:
<div id="weatherWidget" data-serviceid="5bc8362892f347.33127988" data-format="160x160" data-version="1.1" data-city="18220613" data-source="http://www.wetter24.de"><div serviceid="weatherWidgetBlock"></div><script src="http://www.wetter24.de/fileadmin/scripts/widget.js"></script></div>
Is there a known way to achieve this?
We are on confluence 6.11.1
Thanks in advance,
 Martin
Thomas Schlegel
Hi Martin,
just put your code into a User Macro like this:
This works fine for me:
Martin Kaufmann October 22, 2018
Hello Thomas,
thanks. Stil had no time to try that, but I will..!
 Martin
Martin Kaufmann November 22, 2018
Hello Thomas,
still no luck, I can´t get this to even show anything.
But thank you anyway.
 Martin
I have tried to use the macro "widget connector", but I get a rendering error every time.
Maybe its just the wrong syntax, but I don´t get it .. :-(
Regards Martin
