How to make Notify Watchers in Edit page mode to be unchecked by default?
Gregory Kneller
October 1, 2012
Hi mates, can you please advise with the subject? Thanks!
5 votes
Alejandro Conde Carrillo
October 1, 2012
You could try to add this code to your custom HTML (in the dead section)
<script>
  AJS.toInit(function(){
    <!-- Disable "notifyWatchers" checkbox by default (on edit pages only) -->
    AJS.$('input#notifyWatchers').attr('checked', false);
</script>
All credit should go to this page.
Gregory Kneller
October 2, 2012
Hi Alex, so it is only on global level... Thank you for the anwer))
Richard Meadows June 19, 2014
do you need to restart Confluence for this to work?
David Hergert _PAYX_
There is a small piece of JavaScript you can add to your HTML header that will 'remember' if you uncheck the box for a few hours using a cookie. We love it this way, since it allows us to disable it, but it re-enables after a few hours in the spirit of open communication and sharing.
https://confluence.atlassian.com/display/CONFKB/How+to+uncheck+Notify+watchers+check+box+on+Confluence+editor+by+default?focusedCommentId=397083416#comment-397083416
ThreepE0 October 28, 2014
I needed to place this at the end of the body section for it to work for both direct and linked access to edit pages.  Worked great, thanks!
