Version: Confluence 6.5.2
I am having an issue where I have a large data set where I would like to have a full page scrollable view with a locked header, similar to an excel sheet. The issue I am having is, when I put a filter on the table, or lock one of the rows, it shortens my view to 2-3 entries. I have tried expanding the filter box and havent had much luck with it.
Any ideas?
Hello Alex,
Can you attach a screenshot of the issue?
Hi Andrey, thanks for your reply. What ends up happening after I put a filter view on my table, it then limits the number viewable.
i.e., I have 100 number of rows that I can scroll through normally on the page. As soon as I put a filter on that table, I can now only see the first 5/100 rows inside a pre-sized box. I can still scroll through all 100 entries however, I can only see 5 at a time or whatever fits inside my filter box
I guess you have Freeze first N rows option enabled, clear it to disable this feature.
Yeah, I have the freeze N rows selected because when I dont, the header row doest stick to the top of the page while scrolling. Not sure what is going on
Confluence native feature called "table sticky header row" doesn't work if table header row contains merged cells.
That is most likely the cause then. Appreciate your help on this, Andrey
Help us plant more trees
