How to use labels to cross reference pages
louis ortega May 9, 2014
Hi All,
Again, since I had asked another question I am fairly new as a confuence user and I am have set up a tree structure in confluence for documentation content I will be migrating from another Wiki. I understand the very basic of labels. So how can I leverage labels to cross reference to other pages (parent or child). Can you recommend a source in confluence such as a user manual? I am trying to get this done fairly quick and no one else here can tell me much. Thank you
Wayne Wong
June 16, 2014
Can you elaborate more what you're trying to achieve ?
In addition, you can refer to the documentation here for the confluence label usage:
https://confluence.atlassian.com/display/DOC/Working+with+Confluence+Labels
Also, there is another free label plugin here which might help you for that.
https://marketplace.atlassian.com/plugins/com.adaptavist.confluence.labeltools
Thank you.
Hope these help.
Wayne Wong
louis ortega June 22, 2014
Wayne,
Thank you for posting the links and your comments. Very helpful :)
Louis
