I have created a template in confluence navigation to this path is Space tools->Content tools->templates
I have added check boxes and some sample content in the template the below screenshot is before saving the template.
When I try to edit the same template lot of content is missing-Is this the by default functionality of Confluence or can I resolve this issue by doing any work around
Thanks in advance.
Can you please provide a screenshot from your Confluence? Please make sure to hide any personal info.
It seems to me that you are using Confluence Data Center. If it is the case usually an Admin create the template then assign it to your space.
The page should look different.
If you can provide little bit more details it will be very helpful
Best,
Fadoua
Hi @Tinker Fadoua , we are using confluence on prem and confluence is of version 8.5.3
The issue here is if I try to edit the template the data is getting missed,but if I create the page using the template I am getting complete data like bullet points,checkboxes everything
please refer to the attached screenshots:
page created using the template
template when I try to edit it
Please let me know should I share any other details
