×Version is 5.10.2
Hi @Pete Danfy Welcome to the Atlassian Community!
The pre-upgrade planning tool is currently available in the following applications and versions:
Application | Version | Troubleshooting and Support tools version |
Confluence Server |
6.5.0 or later |
1.17.1 or later |
Confluence Data Center | 6.5.0 or later |
1.19.0 or later |
Since you are using older version of confluence, that option is not available to you. Hope this helps.
Hi @Lu Huixian
To access the upgrade planning tool, you'll need the Troubleshooting and Support tools app installed. This is bundled with your application, but you may need to update the app, Learn how to update apps.
Thanks for your answer,I could see trouble shooting option in my general configuration but I can not find the app in my installed apps.could you kindly to tell me the whole name of the app? Thank you!
