I need more then 1Excerpt Macro on one page ,how to do?
zona418@163.com
August 24, 2023
for now, one page can only have 1 excerpt macro, but i need more excerpt from one page ,how to do ?
4 votes
Katerina Rudkovskaya _Stiltsoft_
Hi zona418@163.com,
We can also suggest trying the app that we develop – Table Filter and Charts for Confluence.
Its Table Excerpt/Table Excerpt Include macros will do the trick.
These macros are not only perfect substitutes for the standard Page Properties/Page Properties Report macros if you work with multiple-row tables, but they allow you to reuse tables and page abstracts easily. And, yes, you can have several excerpts on one page.
3 votes
Ollie Guan
August 24, 2023
Hi zona418@163.com ,
Vote for this issue
https://jira.atlassian.com/browse/CONFSERVER-54621
Btw, A 3rd part app MultiExcerpt provides the ability to define and use multiple Excerpt macros from a single page.
https://marketplace.atlassian.com/apps/169/multiexcerpt?hosting=server&tab=overview
Rodrigo
August 24, 2023
Hello zona418@163.com and welcome to the Atlassian Community!
Unfortunately, there is no way to use more than one except macro per page (documentation link).
Here one recommendation could be to work with third-party apps to further enhance this functionality. Out of the back of my head, MultiExcerpt could help you as it can achieve this. And if you are working with multiple templates, there is also Scaffolding templates.
Our team is behind the Navitabs app, which helps you create navigation based on any existing pages, child pages and more, perhaps it could also be helpful?
Hope this helps, and all the best,
Rodrigo
