For a small Project (50 users) and less than 10.000 tickets . I need to know the sizing for
Jira Server
Confluence Server
Data Base Server (MySql). Can I use the same DB server for Jira and Confluence?
Thank you for your help.
Bartolomé Rodillo
Start at https://confluence.atlassian.com/enterprise/jira-sizing-guide-461504623.html and https://confluence.atlassian.com/doc/server-hardware-requirements-guide-30736403.html
And yes, you can use the same db for the stack. You need different database areas of course, but one server with one service is fine.
Thank you. Then I need separate server for Jira and Confluence, I this right?
Thank you again.
Bartolomé Rodillo
Not necessarily. You just need to make sure that if you use one application server, it is powerful enough to run both at the same time. (Even for a reasonably small system, with few users, I wouldn't try it in less than 6Gb RAM on the server)
