Include links in PlantUML
Vikaash Mahabir January 2, 2020
PlantUML supports including links. I've tried this out, but the links aren't clickable. Does any special syntax apply here to make this work?
Boris Jockov
Hi Vikaash.
We are working on an update that will support links and much more.
Stay tuned.
Vikaash Mahabir February 22, 2020
Awesome! ETA?
Boris Jockov
Aiming for the end of Q1.
Update: new release is pending Atlassian approval. Hopefully, it won't take more than couple of weeks.
Like Vikaash Mahabir likes this
Boris Jockov
An updated version has been released. Check it out.
Vikaash Mahabir April 27, 2020
Thanks! I've been notified this is a paid update, so currently my request for this update is being processed by my company's IT budget owner.
sukkeong
June 7, 2021
There is a workaround by setting option 'Image format = SVG'
https://forum.plantuml.net/7270/hyperlinks-working-using-plantuml-macro-confluence-graphviz
Kirstin Seidel-Gebert
January 6, 2020
Hi Vikaash,
Have you already solved your problem?
We have PlantUML installed but I do not use it at all and I'm not familiar with the code. If you provided me with a sample code, I could try if this works on our instance.
Kirstin
Vikaash Mahabir February 14, 2020
Hi @Kirstin Seidel-Gebert , I didn't receive a notification, hence the tardy response... To answer your question: no, unfortunately I have not. You could try the following code to see if it works for you. Mind you, we're using Confluence Cloud.
@startuml
|Department A|
start
:[[http://plantuml.com/start Screen-1]]
Clicks on
button;
:Completes
wizard;
:Task is
handed over
to department B;
|#AntiqueWhite|Department B|
Completes
task created
by department A;
stop
@enduml
This should result in:
 2020-02-22 19_00_02-Bewerken - Redesign proces seizoensomcodering of wijziging van eigendomsmodel - .png
(now the correct diagram that goes with the code ;) )
