Indent Buttons Disabled for Text Blocks
Jason Tolotta
January 4, 2018
Operating System: Windows 10 Home
Browsers: Firefox 57, Chrome 63
The indent buttons are disabled for text blocks as of 2018-01-05.
I know this is a bug, because it works in previous versions.
It works as usual for number and bullet lists.
philoye
February 16, 2018
This change has been reverted. You can indent blocks again.
SMS
January 5, 2018
Hi Jason,
Indeed this was recently disabled in an update to Cloud Confluence.
Have a look at this case for the reasoning and please use it to send your feedback to our developers:
Please let them know your usage case and any other information you'd like to provide them.
Shannon
Davin Studer
January 5, 2018
That case does not talk about the reasoning behind the change.
SMS
January 5, 2018
Apologies, David! It appears it is due to the permissions on the ticket. However, it was an effort to fix some compatibility issues.
My recommendation is to watch the issue in case there are further public updates and comment with your feedback directly on that ticket.
Shannon
