The macro no longer works. No data is displayed.
When an export is made, the following message appears:
Something went wrong: Illegal character in query at index 76:
Hi @Monika Oesch, GILOMEN Informatik GmbH
Welcome to the community.
To be honest we gave up on this macro and started using eazybi reporting for jira and adding the eazybi macro in confluence to display insight data.
That being said, I would check if it works for a small subset of data to determine whether it's you data or the macro itself. Maybe there are some weird characters in your object's data.
Regards
Hi @Fabian Lim
Thanks for your answer, but it's a known issue in Version 1.6.10: JSDSERVER-11096- Insight Macro for Confluence shows white/blank page when the IQL has space(s) in it
Check your filter that is compiling your filter if it does not match your Insight Objects headers exactly it will throw an error.
