Hello fellas, i am bit confuse.
should i install Confluence into a new fresh vps ?
or can i use a linux vps with apache, and install this inside of domain?
and this is the same for Jira?
thanks in advanced
Hi, i was able to install inside of domain that i went it,
but now i am not able to access the app.
i can't call localhost, because this is an remote VPS.
so i tryed my domain and my ip without success
https://158.69.97.218:8080/
https://jira.projetobeauty.com.br:8080
both i got unable to connect
i already check firewall.
do you have an light?
The ssh screen response after installation:
Please wait a few moments while JIRA Software starts up. Launching JIRA Software ... Installation of JIRA Software 7.11.2 is complete Your installation of JIRA Software 7.11.2 is now ready and can be accessed via your browser. JIRA Software 7.11.2 can be accessed at http://localhost:8080
With Apache as a reverse proxy you can run Confluence and Jira on the same VPS, on different ports. Just make sure the VPS has enough resources to run two web severs and a proxy. Here are some resource guidelines for Confluence: Server Hardware Requirements Guide and Jira: Jira applications installation requirements
