Hi Community
I'm trying to install confluence via docker file. Unfortunately the installation aborts with the following error message:
Type Exception Report
Message com.atlassian.util.concurrent.LazyReference$InitializationException: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedTransactionManager' defined in class path resource [databaseSubsystemContext.xml]: Invocation of init method failed; nested exception is com.atlassian.util.concurrent.LazyReference$InitializationException: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedLocalSessionFactoryBean5' defined in class path resource [productionDatabaseContext.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: premature SessionFactory initialisation, Hibernate properties have not yet been persisted in confluence.cfg.xml
Beschreibung The server encountered an unexpected condition that prevented it from fulfilling the request.
Exception
java.util.concurrent.CompletionException: com.atlassian.util.concurrent.LazyReference$InitializationException: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedTransactionManager' defined in class path resource
Root Cause
com.atlassian.util.concurrent.LazyReference$InitializationException: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedTransactionManager' defined in class path resource [databaseSubsystemContext.xml]: Invocation of init method failed; nested exception is com.atlassian.util.concurrent.LazyReference$InitializationException: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedLocalSessionFactoryBean5' defined in class path resource [productionDatabaseContext.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: premature SessionFactory initialisation, Hibernate properties have not yet been persisted in confluence.cfg.xml com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149) com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112) com.atlassian.confluence.tenant.TenantGate.getDelegate(TenantGate.java:166) com.atlassian.confluence.tenant.TenantGate$3.getTarget(TenantGate.java:210) ...
Root Cause
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedTransactionManager' defined in class path resource [databaseSubsystemContext.xml]: Invocation of init method failed; nested exception is com.atlassian.util.concurrent.LazyReference$InitializationException: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedLocalSessionFactoryBean5' defined in class path resource [productionDatabaseContext.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: premature SessionFactory initialisation, Hibernate properties have not yet been persisted in confluence.cfg.xml org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1778) org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:593) org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:515) org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:320) org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222) org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:318) org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:199) org.springframework.beans.factory.support.CglibSubclassingInstantiationStrategy$LookupOverrideMethodInterceptor.intercept(CglibSubclassingInstantiationStrategy.java:290) com.atlassian.confluence.tenant.TenantGate$$EnhancerBySpringCGLIB$$9b6ca63a.createTenantedDelegate(<generated>) com.atlassian.confluence.tenant.TenantGate$2.create(TenantGate.java:71) com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:325) com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:143) com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112) com.atlassian.confluence.tenant.TenantGate.getDelegate(TenantGate.java:166) com.atlassian.confluence.tenant.TenantGate$3.getTarget(TenantGate.java:210) org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:192) com.sun.proxy.$Proxy216.getTransaction(Unknown Source) org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:475)
Root Cause
com.atlassian.util.concurrent.LazyReference$InitializationException: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedLocalSessionFactoryBean5' defined in class path resource [productionDatabaseContext.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: premature SessionFactory initialisation, Hibernate properties have not yet been persisted in confluence.cfg.xml com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149) com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112) com.atlassian.confluence.tenant.TenantGate.getDelegate(TenantGate.java:166) com.atlassian.confluence.tenant.TenantGate$3.getTarget(TenantGate.java:210) org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:192) com.sun.proxy.$Proxy214.getProperties(Unknown Source) com.atlassian.hibernate.adapter.bridge.factory.SessionFactoryBridgeAssociations.associate(SessionFactoryBridgeAssociations.java:78) com.atlassian.hibernate.adapter.bridge.factory.SessionFactoryBridge.lambda$new$1(SessionFactoryBridge.java:43) com.atlassian.hibernate.adapter.util.Lazy.get(Lazy.java:23) com.atlassian.hibernate.adapter.bridge.factory.SessionFactoryV2orV5BridgeProxy.getSessionFactoryV5(SessionFactoryV2orV5BridgeProxy.java:66) com.atlassian.hibernate.adapter.adapters.session.SessionFactoryV2Adapter.getConnectionProvider(SessionFactoryV2Adapter.java:327) com.atlassian.hibernate.adapter.bridge.factory.SessionFactoryV2orV5BridgeProxy.getConnectionProvider(SessionFactoryV2orV5BridgeProxy.java:262) org.springframework.orm.hibernate.SessionFactoryUtils.getDataSource(SessionFactoryUtils.java:116) org.springframework.orm.hibernate.HibernateTransactionManager.afterPropertiesSet(HibernateTransactionManager.java:352) org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1837) org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1774) org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean
Root Cause
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'tenantedLocalSessionFactoryBean5' defined in class path resource [productionDatabaseContext.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: premature SessionFactory initialisation, Hibernate properties have not yet been persisted in confluence.cfg.xml org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1778) org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:593) org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:515) org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:320) org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222) org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:318) org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:199) org.springframework.beans.factory.support.CglibSubclassingInstantiationStrategy$LookupOverrideMethodInterceptor.intercept(CglibSubclassingInstantiationStrategy.java:290) com.atlassian.confluence.tenant.TenantGate$$EnhancerBySpringCGLIB$$c402d44d.createTenantedDelegate(<generated>) com.atlassian.confluence.tenant.TenantGate$2.create(TenantGate.java:71) com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:325) com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:143) com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112) com.atlassian.confluence.tenant.TenantGate.getDelegate(TenantGate.java:166) com.atlassian.confluence.tenant.TenantGate$3.getTarget(TenantGate.java:210) org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:192) com.sun.proxy.$Proxy214.getProperties(Unknown Source) com.atlassian.hibernate.adapter.bridge.factory.SessionFactoryBridgeAssociations.associate(SessionFactoryBridgeAssociations.java:78) com.atlassian.hibernate.adapter.bridge.factory.SessionFactoryBridge.lambda$new$1(SessionFactoryBridge.java:43) com.atlassian.hibernate.adapter.util.Lazy.get(Lazy.java:23) com.atlassian.hibernate.adapter.bridge.factory.SessionFactoryV2orV5BridgeProxy.getSessionFactoryV5(SessionFactoryV2orV5BridgeProxy.java:66)
Hinweis Der komplette Stacktrace der Ursache ist in den Server logs zu finden
My system is an ubuntu server 18.04.
The Docker container runs behind an nginx-proxy with LETSENCRYPT
My Docker-compose File:
version: '3'
services:
dbc:
image: postgres:10
environment:
POSTGRES_PASSWORD: xxx
POSTGRES_USER: confluence
POSTGRES_DB: confluence
volumes:
- ./data:/docker-entrypoint-initdb.d
- ./pgdata:/var/lib/postgresql/data
restart: always
confluence:
image: atlassian/confluence-server
environment:
ATL_PROXY_NAME: xxx
ATL_PROXY_PORT: 443
ATL_TOMCAT_SCHEME: https
ATL_JDBC_USER: confluence
ATL_JDBC_PASSWORD: xxxxx
ATL_DB_TYPE: postgresql
VIRTUAL_PORT: 8090
VIRTUAL_HOST: xxx
LETSENCRYPT_HOST: xxx
LETSENCRYPT_EMAIL: xxx
depends_on:
- dbc
restart: always
networks:
default:
external:
i have tried everything possible, but i always get the same error message, can someone please help me?
Hey Heiko,
The error you're seeing is generally caused by Confluence being unable to contact the database. We can see from the error that Confluence hasn't written the database configuration to confluence.cfg.xml yet as it hasn't been able to obtain a connection.
I can see from the above that the database is being configured in the compose file with
What's missing here is the database URL. From the Docker Repository we have
It is optionally possible to configure the database from the environment, avoiding the need to do so through the web startup screen.
The following variables are all must all be supplied if using this feature:
ATL_JDBC_URL
The database URL; this is database-specific.
ATL_JDBC_USER
The database user to connect as.
ATL_JDBC_PASSWORD
The password for the database user.
ATL_DB_TYPE
The type of database; valid supported values are:
mssql
mysql
oracle12c
postgresql
I suspect all we need to do is add the ATL_JDBC_URL value to the configuration. There may be other issues to resolve, but we need to get this one fixed first.
Please let us know how you get on :)
James Ponting
Premier Support Engineer
Hi All,
I just saw this question is almost a year old, but hopefully this can help anyone else coming across similar issues.
I'm going to mark this question as accepted as it will resolve the issue in question. There may be additional issues to address, but I think they would be better answered in additional questions.
Also, I hope Heiko was able to get his issue resolved!
James Ponting
