I want to install Confluence on a separate Webserver.
Unfortunately I dont find any documentation about this.
The documentations only affect to a standard Linux distribution.
Of course the webserver is also a Linux Server, but I dont have root access, and I dont have access to a console.
So how could I install it onto a webserver?
Tomcat, Java and a MySql Database ist installed.
Thank you.
Michael
only thing you need is root access to the servers shell.
Just install the binary then and configure the application to fit your needs.
create a vhost config and place it in (depends on your distribution) /etc/httpd/conf.d/
a sample config could look like:
<VirtualHost yourservername:80>
ServerAdmin some1@somewhere.com
ServerName yourservername
ServerAlias oryourserveralias
ProxyRequests Off
ProxyPreserveHost On
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
SSLProxyEngine On
ProxyRequests Off
ProxyPass / ajp://localhost:8010/
ProxyPassReverse / ajp://localhost:8010/
<Location />
Order allow,deny
Allow from all
</Location>
</VirtualHost>
please note that this is for a configuration where confluence uses the ajp connector.
i installed confluence on a plesk server configured to use SSL.
i removed some SSL lines here cause there is no need to keep them right now.
reload the apache and you should have a running confluence
you're welcome.
please keep in mind that you cannot copy&paste this one. you need to adjust some lines
now we have the problem more detailed specified. It seems that the Mysql Server is too old.
Now we have to wait a couple of days for the provider updating it.
I will comment again, when I got further informations.
Thank you
Michael
I'm running now Confluence on a PLESK Server inside a PLESK managed Docker Container in a subdomain https://confluence.domain.com, without any error.
if anyone needs help...
best and stay save
Hi, I was hoping to see if you would be able to assist with this? I'm trying to get jira-software running in a PLESK docker container in a subdomain.
Dear André,
Would you be able to share your complete vhost-config (anonymized is fine)?
Update: In the meantime, i've got it to work with the Plesk-Proxy-Configuration.
Best regards
Alex
hello Andre
Can you help me getting Confluence on a PLESK Server inside a PLESK managed Docker Container running?
Docker ist running with Confluence: http://135.181.62.38:8090
But when I add Proxy Rules for zahnmedizinforum.de
zahnmedizinforum.de/confluence It does not work
hey i have the same situation,
way Atlassian, doenst help us in this way, an tutorial solve the issue.
we are not lazy, but we need an minimal assistence.
here the file that you posted,
<VirtualHost sub.domaininstalled:80>
ProxyRequests Off
<Proxy *>;
Order deny,allow
Allow from all
</Proxy>;
SSLProxyEngine On
ProxyRequests Off
ProxyPass / ajp://sub.domaininstalled:8080/
ProxyPassReverse / ajp://sub.domaininstalled:8080/
<Location />
Order allow,deny
Allow from all
</Location>
</VirtualHost>
that is it?
Hello Lucas,
thank you for your answer. But the answer ist not really satisfying. We invested a lot of money for the donwload-license, and now we could not use it....?
The on Demand licence is patently too expensive, because of this we choose the donwload licence.
If I could get root access on a console, is it then possible to install on the webserver?
Thank you
Michael
Confluence was not intended to be installed on this kind of scenario. You'll need root access to perform the instalation.If you want a completely "cloud" experiance, please consider Atlassian OnDemand services.
Lucas Lima
Atlassian Support
