Is it possible to create a KB article from worflow screen?
Mafalda Sanches October 4, 2018
I wonder if it's possible to create a knowledge base article directly from a workflow screen. In this specific, in the transition screen 'Resolve' from several status to 'Resolved' I want to be able to create directly KB article besides from setting the resolution. Is this possible?
Gregory Van Den Ham
Hi Mafalda, there are two or three ways this is possible.
Take a look at:
Easy Integrations for Jira
and
Run CLI Actions
There's always Script Runner as well that can likely take care of this.
Mafalda Sanches October 6, 2018
Thank you Gregory for your help!
