×After upgrading confluence to 7.13.2 (server) the blog post navigation tree shows only 25 recent posts per month, why? Is there any configuration/hack/whatever to list ALL posts created per month?
Honestly, I really don't understand the logic for limiting the amount of posts showing in the navigation tree where the user should be able to see all the posts.
Br,
Maria A
There is a setting that allows a maximum number of posts here: https://confluence.atlassian.com/doc/blog-posts-macro-139470.html
I hope this helps
Hello Fabian,
I'm not using the blog post macro in this case, so those setting are not available unfortunately.
I'm using space Blog where the settings are very limited. I can not find such a setting where you could determine max nro of posts showing on the navigation bar.
Br,
Maria A
