×Hi!
We use Confluence Data Center 8.1 and Jira Service Management 5.6.0. We want to integrate Jira Assets with Confluence.
@Seyyede Reyhane Khakshoori Hi. there is a widget you can use in Confluence that will pull data from your Assets schemas. When you are in Confluence, you will select the widget add on button in edit mode, and search for Assets. The widget will ask you what Schema you are wanting to use from Assets. You have to enter AQL language in order to pull the data you want.
@Seyyede Reyhane Khakshoori If you are hoping to use Jira assets within Confluence the answer is no. If you would like to have some reporting in Confluence you the answer is yes. You can use the assets widget to pull assets scheme in. You can also use Jira filter macro but it will be limited to what you can return in a JQL filter.
