Is it possible to transform Lucidcharts to Gliffy?
Martin Heini
I have to import a Confluence space from an external instance. They worked with Lucidcharts, we are using Gliffy. How to save the charts in our Confluence with option for editing those?
Trupti Kamble February 19, 2020
Hello Martin,
We are using Lucidchart on prem for Confluence and as they are ceasing support for this we will need to go for gliffy plugin. Can you please help here know if you success-ed to convert Lucidchart diagram to Gliffy?
David Benson [draw.io]
February 19, 2020
Gliffy can import draw.io files, so assuming Gliffy don't have a Lucidchart importer at the time of writing, you could import the Lucidchart diagram to draw.io, then import that into Gliffy. https://desk.draw.io/support/solutions/articles/16000104665-migrate-from-lucidchart-onprem-to-draw-io
Edit: Gliffy do now have a Lucidchart mass importer under BASE_URL/admin/plugin-repository/gliffylucidchartbatchconverter.action
Jennifer Hall October 3, 2020
The batch converter does not work for lucidchart onprem. It only works for diagrams created with lucidchart diagrams connector.  We are faced with the same issue.
Like Adeola Lawal likes this
Adeola Lawal
May 10, 2022
@Jennifer Hall  Please do you have any information on whether this is still an issue or not? I have recently tried to convert Lucid chart images to Gliffy image using the Gliffy batch converter but the lucid chart diagrams were not found by the converter
Jennifer Hall May 10, 2022
it's  still very much an issue.
Samie Delebo - Your Gal at Gliffy
Hi @Jennifer Hall and @Adeola Lawal ! I will pass the feedback along to our product team that you're looking for the ability to convert from Lucidchart's onprem app — not just the diagrams connector.
Adeola, please also feel free to reach out to our team at support@gliffy.com if you'd like help troubleshooting further!
Martin Heini
Thanks for the tipps. However we decided for the static import of images.
Trupti Kamble May 28, 2020
Hi Martin,
Can you please help to know how you are importing images?
Martin Heini
Hi Trupti_Kamble
sorry, 'importing' sounds too good; we exported the .png files from external instance and attached them in the other instance, very simply.
John Almeida
September 25, 2019
Hi Martin,
At the moment, you can only import Gliffy files (.gliffy, .gon, .gxml), Visio files (.vsdx, .vdx) & Draw.io files (.drawio, .xml).
If you are able to export from Lucidchart to any of these file types, you will be able to import to Gliffy. Hope this helps!
