Is there a reference list for Confluence versions and their associated AUI version?
Sharon Hinde
August 14, 2018
Google shows me ways to get the AUI version but I'm hoping for a more user friendly way to find out your AUI version, so users know which icons may be available in their Confluence.
3 votes
Daz
December 6, 2018 edited
Hi Sharon,
There's a list of Atlassian products and the version of AUI they use here: https://bitbucket.org/atlassian/aui-adg/wiki/versions/product-version-matrix.
In-product, you can check the version of AUI that's used by checking the value of the `data-aui-version` attribute on the <body> tag.
I'm not sure if either of these qualify as "user-friendly" approaches to retrieving the version, however... there's a bit of a breadcrumb trail to follow to get the information you actually want.
Hope that helps,
Daz
Sharon Hinde
December 18, 2018
That's brill as a starting point, thanks Daz!
Diego
August 24, 2018 edited
Hello Sharon, thanks for contacting our community!
Dealing with the AUI documentation shoud be quite straightforward. We do have a list of our AUI versions right here:
Atlassian Archive
However a explicit list of the AUI version used with each Confluence version is not available. You could search for Preparing for Confluence in our knowledge base. When the AUI version is changed, it will be listed there:
You can also check the current guidelines here:
AUI Server
If you need to check the version used in your project, you can refer to the data-aui-version attribute:
AUI FAQ
Let us know if this helps your team!
Sharon Hinde
August 31, 2018
This is the information I was hoping for but if its not there then I will have to think of another way, thanks.
