  • Community
  • Products
  • Confluence
  • Questions
  • Is there a way in which a particular section within a document be linked from another link without having to update the link always in case the section title is changed.
sidhartha
For example, I have two documents A and B. The document A has many sub sections X1,X2. I want to include a link in document B such that it points to section X1 in document A. Please note that the title of the X1 section might be changed and that I do not want to document B to repeatedly change the link in order to avoid link breakage. I know that using tiny URL helps while pointing to a document as a whole. Is there any such thing while linking to sections within documents?
Stephen Deutsch
February 12, 2015
instead of linking to the sections, why not create an anchor macro along with each section heading?  It's a bit more work, but it would prevent losing your links.  Other than that, I'm not aware of any function to avoid link breakage to sections.
Help us plant more trees
