Is there a way to copy a space
NM
The Atlassian CopySpace plugin is not compatible with Confluence version 6. Is there another alternative please?
Btw. it is about time that Confluence gives this feature out of the box. It is pretty important functionality.
Davin Studer
May 5, 2017
It still works with Confluence 6. I use it all the time. You just have to manually download the JAR file an upload it. The reason it says it is not compatible is that they just have not tested it yet. But if the underlying APIs that they use haven ot changed, then it will still work. Typically I found that even though an add-on does not say it is supported it still works. Atlassian requires add-on developers to go in and says explicitly that ther add-on still works.
Maarten Cautreels
May 5, 2017
Hi Nirdesha,
Copying a complete space is not officially supported by Atlassian but they do have a knowledge base articles about that with several options (from plugins to manually exporting/importing a space): https://confluence.atlassian.com/confkb/how-to-copy-or-rename-a-space-in-confluence-169578.html
Hope this helps,
Maarten
Nancy Jaiswal November 10, 2017
Our Copy Page Hierarchy (Copy Space)  plugin could be used to copy whole space or desired set of pages (along with attachments) to a new space. I think it matches your requirement.
EPS Software Engineering AG
May 8, 2017
Our Add-on Space Tree Creator can copy spaces. But creating spaces from a template is the main purpose. The creation process is started by clicking a button and filling out a form.
So, give it a try: Marketplace Link.
Jan-Peter Rusch
May 7, 2017
Another solution for customers using the Scriptrunner AddOn is using build-in copy space script. Anyway, copying a spec should be a supported official function of Confluence.
AnnWorley
May 5, 2017
Regarding the suggestion to include Copying spaces "out of the box" we do have a feature request open: Easily create a copy of an entire space The ticket is public and we welcome your feedback.
atlassian, confluence whiteboards, whiteboard templates, template contest, visual collaboration, atlassian learning, confluence community, brainstorming tools, agile planning, team productivity, confluence templates, share your template
Share Your Confluence Whiteboard Template for a Chance to Be Featured in the Product! 🏆
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!
