Is there a way to disable strike-through in Confluence?
Rob Moser
Confluence's editor likes to take anything between - marks and turn it into strike-through text.  That's probably great for some people, but we use our Confluence to document - among other things - unix commands used for various tasks.  Lots of those commands have -'s in their names, and almost all of them use 's to delimit arguments; if you're not paying attention when you type, you end up with struckthrough garbledygook.
Actually, I'm just going to leave that there like that, as a case-in-point.
Is there a way to turn this behaviour off?
4 votes
Steffen Heller
October 30, 2014
Have you tried Settings > Your Settings > Editor > [x] Disable Autoformatting?
Rob Moser
No, I had not. No idea that option was there; it does the trick perfectly. Thanks!
Mike Rathwell
October 30, 2014
D'oh! I shoulda thought to look there but... I didn't. Thanks for the tip. Have made several people here very happy.
Mike Rathwell
October 30, 2014
  1. If anyone comes up with an answer, I'd like to see it; we also have the problem.
  2. A kludge (but it works even if annoying) is to use the code block macro for this purpose. Then the wiki markup imposition goes away
Rob Moser
Yeah, I use the code blocks too, but for smaller fragments it would be nicer to have them inline.  And mostly it would be nice to be able to type without worrying about the text getting changed underneath me.
As I said, I can see the value of the feature in some environments; I'm not asking for the default behaviour to change, I'm just wondering if there is some way to turn it off for our site.
MJ
July 12, 2017
Use an Escape special character (https://jira.atlassian.com/secure/WikiRendererHelpAction.jspa?section=all)
Example:
Notation =>   -NO\-STRIKE
Result +>   -NO-STRIKE
Rob Moser
Thanks MJ.  Doesn't solve my problem, as I wanted to be able to just type (and cut-and-paste) without having to worry about going back to escape things.  But it may well be useful to someone else who finds this thread.
Madhu Mani
August 13, 2018
Dennis
July 31, 2020
Even if we can disable this through the settings auto format, having this as default behaviour is RIDICULOUS! It's not only for commands you use dash. It's used in normal writing too. You should change the letter combination to trigger strikethrough (or perhaps turn it off by default).
Learn more
