×I have tried adding the URL as an external gadget, but the URL is not in the correct format for a gadget.
Hello JT,
I am unaware if Innotas has direct gadget compatibility I suggest contacting their support group. I have however found a plugin you could use. It seems to apply to your case in terms of displaying the charts. I suggest reading up on the plugin before purchasing or consideration of using it.
